Hi group. Newbie here. Anyone know how to get a repair manual for a RCA P52820BL. Having convergence problem. I should be able to fix myself. Some TV experience. Thanx group.
RCA ColorTrak Plus-27"-No channels below 51' I woke up from a nap yesterday and found that I could no longer get channel "line in thru 50". When I went into the set up menue I tried auto and manule programing, they all seem to be "enabled". It seems like it must be a hard ware problem to me. Anyone have any suggestions. Thanks Martian
Not sure if this process applies to the same model. but here is a little something i found . This applies to model P56830BL, but may work with similar models that were manufactured around the the same time or with in a couple years appart...
Service Mode Most of the alignments for this chassis are software-driven; adjustments are made by modifying parameter values using Chipper Check and the service menu. When parameter values are modified, the corresponding T-chip registers, tuner registers and EEprom locations are updated. A list of the software alignment parameters accessable using the front panel is shown in Table 1. The remainder of the alignments require Chipper Check®. Page 3-2 Entering the Service Mode Using the Front Panel Controls 1. Press and release the POWER button to turn the instrument on. 2. Press and hold the MENU button. a. Press and release the POWER button. b. Press and release the VOL+ button. 3. Release the MENU button. The instrument will display the following menu: The CH Ù and CH Ú buttons on the front panel (or the remote transmitter) are used to change the parameter (P) number. The VOL + and VOL - buttons are used to change the parameter value (V). NOTE: Attempting to change the parameter number (using CH Ù or CH Ú) at this point will cause the instrument to exit the service mode. A valid security code must be entered (using VOL + or VOL -) before selecting an alignment parameter. Security Codes When the service mode is first turned on, the parameter will be "0", which does not correspond to an alignment. This is the security code parameter, the purpose of which is to prevent accidental entry into the parameter groups. The value (V) must be set to 76 for Front panel access to chassis alignments. The value (V) must be set to 80 for Front panel (remote control) convergence adjustments or to 200 for Chipper Check®. Once Chipper Check® mode (V=200) is selected, the Chipper Check® interface box will take control of the instrument and the front panel will become inoperative. Once a security code has been set, pressing CH Ù or CH Ú will result in the following display: Where: YY = parameter number ZZZ = current value At this point, the CH Ù and CH Ú buttons can be used to change the parameter number and the VOL + and VOL - buttons can be used to change the value of the parameter selected.
Note: be very careful in what values are changed, also before changing any values it might be a good idea to wright them down so that you can refer to them if need be..
Your eeprom and or the tuner is probably bad. Changing values in the menu will not fix your problem I'm afraid and could damage the set even more. Good Luck.
Hello ,
I have a RCA D52W20B HDTV . It clicks on but has no picture then shuts off
Service Mode
Page 3-2
instrument on.
Security Codes
ZZZ = current value
selected.
Hope this helps someone..
