My reciever constantly goes into 'Protector' mode when cutting it on. I have to power off then on again several times before it remains on. I've checked the peaker wires for cuts and made sure they are secure
The problem I have is that the reciever doesn't always go into Protector mode every time I use it. It may happen 5 times in a row then not happen for several days
I have a sony reciever as well and was was having the same problem. I contacted sony and was told that the unit will usually go into "protect" mode when it gets to hot so as to avoid damaging the internal components. Once I opened the space around the unit and provided better airflow (this can be done cheaply with a small cooling fan like the kind computers use) I have not had the problem since. I hope this helps.
I also have a Sony receiver and its been sittin around becuase it will never power on without bein in "power Protect" and i unhook everything, still the same thing, and i turned it all the way down, and still same thing
Not only Protect mode kills patience... there is one more thing... I get a message :Unlock: for some modes like DVD - Surround... I lost my main remote... so I engaged a Universal remote... and can anybody tell me how to unlock this by using main buttons on the receiver
Don't worry about the unlock message. Many Sony receivers, for some strange reason, display the term unlock when the reciever is set to use a digital input jack, but no digital signal is present. If you hooked up a DVD or CD player using a digital connection, the unlock message would disappear.
I am trying to use the coaxial cable to listen to surround sound, but the receiver keeps showing "unlock" when on coaxial mode, I can only receive sound in analog connections, any ideas?
I also have a sony reciever str-de525 & its stuck in protection mode . I've tried everything to get it out of the protection mode and still no luck . There isnt anything blown on it , ive went through everything and i still dont know how to fix it . & i have the orginal remote to it , is there any way i can unlock it with the remote or no ?
Do these 2 tests:
Does it cut out if the volume is all the way down when you power it on?
Disconnect everything from the receiver except the power cord. Does it still cut out?
any help would be appreciated
pvkrishna76,
Hi, I have a Sony FM Stereo/FM-Am Receiver STR-DE525 Digital Cinema AUDIO/Video Control Center.
I have lost my remote. What universal remote control can you recommend that I buy?
Frank
HAVE A DE 525 RECIEVER AND IT FLASHES PROTECTOR AT ALL TIMES . I HAVE NOTHING HOOKED UP BUT THE POWER CORD AND STILL THATS ALL IT FLASHES ANY IDEA ?
Hi, I have a Sony FM Stereo/FM-Am Receiver STR-DE525 Digital Cinema AUDIO/Video Control Center. The "protector code" every time the unit is turn on.
