We have a 50" Pioneer tv. The color is showing a shadow. We tried the conversion but that did not work. Any ideas. It is a projection tv about 6 years old. Thank you
The shadow is different colors. When we do the conversion the colors on the x are not aligned. It says to use your up and down button to align them, but they won't go together.
I have a sony 52 inch KP53V75 the overal color has a pink cast I cannot adj the color to correct it, can this be fixed it is 5 years old, buy another set?
only1girl, the discoloration should go away the more you turn on your TV from a cold start. If it does not go away, try to unplug the set for a good 12 to 24 hours, then plug in. It should get better everytime you do this. If it does not, then you have a problem with the automatic deguassing circuit inside the TV set. This is not somthing you want to mess with. its a repair job for a pro. But im guessing , you will wake up tommorrow and see a good picture once again. Let us know how you made out. Good Luck
Suggest you call someone out to deguass your screen. Your tv does have a built-in one but it's not as powerful as the hand held ones used by repair techs.
Larry Dillon said: only1girl, the discoloration should go away the more you turn on your TV from a cold start. If it does not go away, try to unplug the set for a good 12 to 24 hours, then plug in. It should get better everytime you do this. If it does not, then you have a problem with the automatic deguassing circuit inside the TV set. This is not somthing you want to mess with. its a repair job for a pro. But im guessing , you will wake up tommorrow and see a good picture once again. Let us know how you made out. Good Luck
Hi Carol, sorry to hear about your shadow problem.
Is the shadow of another color, or is it something different?
I had a similiar problem. The convergence output inside my TV had to be repaired:
http://www.techlore.com/forum/thread/11061/
I have a Zenith TVZ2541 tv/vcr combo! problem is vcr part messed up! can i disable the vcr from operating so that the tv works without the vcr?
My son placed a magnet on our tv and now we have purple and green spots on the screen. anyone know how to fix this?
thanks guys for the tips. It actually was back to normal the next day. Take care =:)
Glad to hear it only1girl!! Comeback to see us again. And dont forget to tell your friends about http://www.techlore.com
