HELP I have a 60 inch RCA projection tv that will not turn on it is making three clicking sounds when i try to turn it on... i called a repair shop and they told me to unplug everything for 2-3 hours that did not work.... is there a fuse that may be blown????
They told you the right thing to try first - unplugging the TV for a period of time. Since that didn't work, you should try an authorized RCA repair center. You shouldn't poke around inside a TV unless you know what you're doing. Here's a related thread with the contact info:
http://www.techlore.com/forum/thread/11212/
Wow! What a great site! I have a 1996 Sony Model # KP-46s25 46" Projection TV that has been making a clicking sound and recently started to "separate" into 2 and sometimes 3 distinct colors. Is this a module or something I can replace myself? I had somebody out a year ago and he spent about 10 minutes the first time and about 10 minutes replacing 1 part for $300 +. Thanks.
As I said above, even if you knew what it was, I wouldn't recommend trying to fix it yourself. Unfortunately in this case, your best bet is probably to call a serviceman as painful as that may be.
Please someone help me. I have a Sony 61" Tv KP-61V90. I just realized thias problem todya . My TV has a black shadow like discolotring on the top corner of the TV .I am not sure ,but I think it may be the color tube .Is anyone familiar with the description I gave ? If so do U have any good advice for me as far as repair .
Thanks Jody
Are there any strong magnets by that corner of the TV?
i have a rca mod#f27638bc chassis#187ab that i can,t focus or get a clear pix i,m an old tv repairman [74] and well versed on tubes but i try to stay away from the new stuff it looks like in the old days when the yoke got moved [but it hasent ] and has color around outside edges flyback prob maybe thnx swampy
I disconnected the high voltage cord from the CRT so that I could take the circuit board to be repaired. I used a plastic screwdriver and popped the high voltage wire from the top-back of the picture tube. I want to know how to put the cord back into the tube.I also want to know if the high voltage is still present.
Hi i have a 45"mitsubsihi big screen tv,when i trun it on i get a sound then it trun off.What do you think it could be
Have you tried unplugging it for 4 hours as suggested above?
I have a 60 inch RCA home theatre TV, Model #P60152CK, I was watching it and it just shut off. When i try to power it up the green power light comes on for a second but thats all. I had this happen once before and the repair man knew what the problem was and said thats the only thing that ever goes wrong with this telivision, This repair man has since died . Is anyone farmiliar with this and if so do they know what part # I need.
Nick
This may help.
http://www.techlore.com/article/10446/
I have a sony dvd, home theatre system #SS TS 502~
I have a tv, that I've added a universal remote too that I have tv, vcr, and dvd linked to ~
As i use the dvd player, i can put dvd in, no problem, hit play, and we can hear the movie, but will not show up on the TV ~ I am going nutz trying to figure this out, and of course, I cant find the book that belongs to the player.... please help if you can, and advise what I'm missing........
