Lost inputs
5 posts / 0 new
jeremy
Lost inputs
I've got a mitsubish 60 inch crt 99 model I believe, and the power went out not long ago it was on a surge protector, but when it started back up only ant a and b are working not the other inputs 1-2-3. Is there a way to reset this or did it get fried?
Matt Whitlock (not verified)
Mitsubihi does not have any
Mitsubihi does not have any documentation available for any TVs from that model year. However, I personally owned a VS-45607 at one point many years ago. So bear with me, I've got to work from memory.
If I remember correctly, the set I owned (from the 98 or 99 model year) had the ability to disable external inputs in the TV's on-screen menu. You may want to try poking around the menu a little, but I could probably tell you where it's located if you can tell me what the menu structure is (first and second layers)... which would probably be enough jog my memory.
If I had to guess, it will be somewhere in "Setup" or "Advanced Features/Settings".
jeremy
Thanks I looked around and
Thanks I looked around and figured it out. Thanks for the tip ;o).
Ron Repking (not verified)
What was the answer? Let us
What was the answer? Let us know so we can help the next person with this problem! :-)
Let us know how you enabled
Let us know how you enabled the inputs. Where in the menu was it located? What did you do to correct the issue?
