It's no secret that it takes a lot of knowledge to truly understand the world of home audio, which is littered with confusing numbers and terms. Wattage, current, distortion, frequencies, and impedance are just a few of the specifications anyone looking for an amplifier of home theater receiver is going to come across. With the thousands of choices in each category, it takes a little bit of background to use these specifications to make a great choice.
In steps the watt...
Evaluating and stating the wattage of an amplifier has become the single most important number to the amplifier shopper. Unfortunately, wattage is a highly misunderstood specification, which dupes people into buying products with a level of performance much lower than what is anticipated. 100 watts seems to be the magic number for most, thinking that as long as you have 100 of them, and no less, they'll be fine. However, even passenger side mirror on your car states that things aren't always as they appear.
To be fair, wattage is an important number that can give a clear understanding of an amplifiers performance. A Watt, named after the British scientist James Watt, is a unit of power. And since power is expressed as a unit of energy divided by a unit of time, a watt is commonly defined as a unit of power equal to one joule per second. Simply stated, a watt is the amplifiers ability to do work, like make the drivers in a loudspeaker move.
Wattage in an amplifier is like horsepower in a car. The more horsepower a car has, the faster the car goes. But unfortunately, this isn't always true. Take into consideration that a 150 horsepower engine might be able to rocket a 1200-pound car, but it's not going to budge a 5-ton semi-truck. The weight of the car is similar to the weight (efficiency) of the speaker connected to an amplifier.
Standardizing the Specs (sort of...)
In the competitive atmosphere that has taken over the entire electronics industry, manufacturers and marketers struggle to make their products appeal to the masses. Of which, massaging the specifications of their products is a sure fire way to attract buyers in a sea filled with similar products.
There is, to this day, no truly defined way to measure the power output of an amplifier. As you will learn below, the numbers do not mean much until they can be understood in context, and broken down in a manner that allows fair comparisons between products.
When amplifiers went from tube amplifiers (that use vacuum tubes) to solid-state amplifiers, power ratings for amplifiers got extremely confusing. Finally, the FTC stepped in ruled that all power claims had to include the conditions in which they were measured. Unfortunately, the FTC did not rule that amplifiers had to be tested on the same playing field. This means that in order to make fair comparisons, one would need to know how to interpret what the conditions of the measurement means. Specifically, the FTC ruled that:
- Power measurements must be stated in RMS (sustained) watts.
- The bandwidth (band of frequencies) used in the measurement must be stated.
- The impedance (load) had to be stated.
- The number of amplifier channels played into that load had to be stated.
- Total harmonic distortion figures had to be stated.
Specifications Explained
More often than not, looking at amplifier specifications can reveal a great deal about the amplifiers real world performance. Below is an explanation of each specification, and how to interpret them.
RMS Power
Bandwidth
Impedance
Number of Channels Driven
Total Harmonic Distortion (THD)
There are two ways of expressing power, peak and RMS. Peak power is the amplifier's ability to provide an instantaneous burst of power. However, peak power measurements are somewhat fictitious since they cannot be sustained for long. RMS (Root Mean Square) power ratings are a mathematically correct way to express an amplifier's usable average power, which is a representation of real-world performance.
Bandwidth refers to the frequency range used to produce the claimed power specification. Most amplifiers have a harder time producing the frequency extremes, such as low bass frequencies or high treble, than it does with midrange frequencies. Humans with perfect hearing can discern a frequency range from 20Hz to 20kHz (20,000Hz). Since music and movie soundtracks involve a very wide range of frequencies, it is good to know what range the amplifier was tested under. This ensures that the amplifier can hold its own producing the dynamic effects of music and movies.
Many manufacturers often try to massage the specifications of amplifiers to give them a higher claimed wattage. When you see a power rating that says "x watts @ 1 kHz", it means that they only tested one specific frequency to get its power rating. Not only does this not give you any indication of whether or not the amplifier can hold its own during frequency extremes, but it is unfair to buyers since the measured wattage would be considerably less if all frequencies had been used.
Solid-state amplifiers usually produce lower wattage into higher impedances (electrical resistance) than lower impedances. This, however, is not always true for tube amplifiers.
According to Ohm's Law, a perfect amplifier would produce twice the wattage into a 4-ohm load than it does into an 8-ohm load. But since lower loads can drain amplifiers quickly, the power supplies tend to produce less operating voltage. So in the real world, lowering the impedance of the speaker will not necessarily yield twice the wattage from the receiver.
This is another way that manufacturers can fool consumers. When evaluating power specifications, the output wattage will typically be larger when a lower impedance is used for testing.
Long ago, when amplifiers had only two channels, the term "all channels driven" meant that the test included both amplifiers being tested simultaneously. Today, products contain 5, 7, or even 10 amplifiers in one chassis, and this term can be a bit deceiving. It would make sense that "all channels driven" would mean that every channel in the product were all tested simultaneously, but unfortunately, this is not always true.
Manufacturers can cheat a little bit when testing the wattage of a receiver. If, for example, a product contains 7 amplifiers, yet they only used two of them at the same time while testing, the claimed wattage on the receiver would be significantly higher than if all 7 amplifiers had been used. It is important to read the fine print to find out exactly how many amplifiers had been used for the test.
Distortion measurements do not necessarily speak volumes. At some degree or another, all amplifiers introduce distortion, which is when an amplifier changes the input signal. In most cases, the distortion increases as the power demanded grows. Distortion measurements can give an indication of when an amplifier is operating in a non-linear fashion.
Manufacturers can also use this specification to their advantage. As stated above, claimed wattage is the effect of the test variables. So, if the manufacturer chooses to turn up an amplifier until it reaches 10% THD, they could report a higher wattage (even though it would probably sound terrible). High wattage at very low distortion is desirable.
Comparing Specifications - An Example
Here are some real world power specifications to compare. While reading them, try to figure out which one is probably the better amplifier. For this example, assume that both amps in question contain five channels.
Amp #1 - 75W per channel, 5Hz - 80kHz, @ 8 Ohms, 5 channels driven with no more than .08% THD.
Amp #2 - 100W per channel, 80Hz - 20kHz @ 6 Ohms, 5 channels driven with no more than 1.0% THD.
So the question on everyone's mind is, "Which one is the better amplifier?" At first glance it may appear that #2 is the better amp, considering it boasts 25 more watts than amp #1. However, the surprising answer is that amp #1 is probably the better amplifier. Here's why:
- As you can see, the stated frequency response on amp #1 is considerably wider than amp #2. This means that amp #1 was producing a much wider range of extreme frequencies than the second. In fact, amp #2 cut out low bass frequencies entirely, indicating that it may not be able to hold up under extreme bass passages.
- It also shows that amp #1 was tested using a higher impedance than #2, and as you learned above, higher impedances produce lower wattages. Amp #2 used a 6 ohm load, which would give it a higher claimed wattage than if it had used an 8 ohm load.
- Amp #1 has less distortion than amp #2. While distortion is not always a clear indicator of an amps sound quality, it does show that #1 is altering the input signal much less than amp #2. Considering that amp #1 was tested harder than #2, it's impressive that it maintained low distortion under a rigorous test.
Buying Tips
Manufacturers can be somewhat deceptive about amplifiers, especially the ones in the bargain section of your local electronics store. Below are some general things to look out for when shopping for an amplifier.
- When comparing specifications, try as hard as possible to bring them to the same playing field. So, if one amp has a 6-ohm rating and the other an 8-ohm rating, tell yourself that the 6-ohm rating was used for a reason, and that the wattage would be lower if an 8-ohm load had been used.
As we learned above, a perfect amp would produce twice the power into a 4-ohm load as it would into an 8-ohm load. That being said, a perfect amp would produce 1.5 times the power into a 6-ohm load as it would into an 8-ohm load. However, we all know that power supply limitations make this untrue. Be conservative in your estimates. In the examples above, if you decide to state amp #2 as 8-ohms you could divide 100 watts by 1.5 to get an answer of 66 watts. However, remember that the manufacturer avoided the low bass frequencies, so the true power output may only be around 55 watts (depending on the power supply) if full range speakers are used.
- Amplifiers that claim "x watts @ 1 kHz" should not be trusted. Their real world performance could be less than half of what the claimed power specifications say. The test bandwidth for any power claim should be at least "x-watts @ 20Hz-20kHz).
- Amplifiers with "one channel driven" should not be trusted. It indicates a serious problem with the amplifier's ability to produce high wattage under real conditions.
- Be cautious if someone tries to sell you on fictitious "peak" power ratings. While they might seem impressive, they say nothing about how the amplifier actually performs.
- Watch out for distortion ratings. Within limits, lower numbers are more desirable, but usually anything under 1% is inaudible.
- Keep in mind the speakers that will be connected to the amplifier. If you have big, high quality speakers, an inexpensive amplifier probably is not going to help you get the most out of them. Likewise, there is no reason to go overboard on an amplifier for inexpensive speakers.
- When shopping for an integrated receiver (where there is processing and amplification in one box), keep in mind that there are other features that may be just as important as the watts as mentioned above.
- Price is not always a clear indication of amplifier quality. However, in many cases, there are reasons why great performing amplifiers come with a higher than expected price tag.
