How do you take the back off the Sony Ericsson S710a to take the battery out?
-submitted by lauren1987
I ran into the same problem when I first purchased my Sony Ericsson S710a. The back plate is difficult to remove. In all honesty, it comes off the same way you would expect it to. However, it is very tight, so it requires a little elbow grease to get it off.
The best way I've found of removing it is to hold it in both hands with the back of the phone facing you. Make sure the lens of the camera is at the top, and not the other way around. Position your thumbs as shown in the picture, press down with enough pressure that your thumbs won't slip that much, and pull your thumbs back toward you. It should come off rather easily.
Did You Know...
Cell phones could one day not only work across the entire planet, but across the entire galaxy as well. Read Jeff Block's article "Tear Down the Cell Towers?", to learn how quantum tunneling could be coming to a cell phone near you.
Is your cell phone not working that well anymore. TechLore member, Donna, had a Verizon phone that wasn't. Read her article "Can you hear me now? Hello?", and learn what Verizon did about it.
While You're At It...
Check out TechLore's exclusive review of the Sony Ericsson S710a Mobile Phone by Matt Whitlock.
