What is the best way to enhance the screen resolution on an RCA 52" rear projection TV (yr. 2000 model P52927) to allow for HDTV, or is that not an option?
-submitted by fueltech9
There are three distinct types of TVs that have been sold over the last 7 years: analog, HD-Ready, and HD-Integrated. HD-ready and HD-integrated TVs are both capable of displaying high-resolution images, the only difference between them is that HD-ready TVs require an external HDTV tuner before it can display any HDTV programs. Integrated sets already have one built in for terrestrial broadcasts, and sometimes cable.
Analog TVs, such as the RCA P52927, are incapable of displaying resolutions greater than 480i. These TVs are bound to the analog NTSC TV system, and they cannot be enhanced or upgraded to be otherwise. Unfortunately, a new TV will be required if you wish to enjoy the stunning detail and depth of HDTV images.
If you are concerned that analog television programming will go away in the short term, you will not be forced to make any TV upgrade if you do not wish to. Even when the hard DTV transition date (currently projected between 12/2008 and 4/2009) hits , your existing display can be connected to an HD downconverter box which will turn HD images into standard ones compatible with your TV.
Did You Know...
To learn about everything you need to recieve and view high-definition programs, read the article "What do I need to watch HDTV?".
There are many options in the menu of your TV or other electronic device that needs to be adjusted before you can get the most out of your device. Read "Navigating the Device Menu on Your Components" to learn more.
While You're At It...
Worried that your children's video games may damage your TV set? A few small precautions can make a world of difference when it comes to protecting your TV. Read "Does playing video games cause permanent damage to your TV?" to learn more.
Is your TV screen covered with dust, dirt, and grime. It's time to clean, but cleaning it the wrong way can damage the screen or cabinet. Read "How to Clean Your TV Screen" to learn more.
