Mitsubishi WS 65711 Problem with Green portion of image being way off.
7 posts / 0 new
tlhjackets
Woke up this morning and the green projection image is way off like a few inches. I can't check for error codes the typical way because the control board went bad earlier this year and I had to unplug it. i know the set will only adjust the blue and red so i was not sure this is just a convergence problem or something else. Any help would be greatly appreciated.
evil
Certainly sounds like a
Certainly sounds like a convergence issue click HERE for a good quality replacement part.
tlhjackets
I ordered the repair kit and
I ordered the repair kit and will give it a try. Thanks for the input Evil. Does anyone know where I can get a replacement front control panel. The one with the power and other buttons on the front of the TV. Thanks.
evil
Are you mIssing it or is it
Are you mIssing it or is it just not working?
evil
One of these will help you a
tlhjackets
Hey Evil,
Hey Evil,
I had to disconnect it because it went bad. So I am looking for a replacement.
Thanks,
Tim
evil
http://www.google.com/m
