Mitsubishi WS-65908 error code 22
4 posts / 0 new
parkie7
Tv is 10 years old and have had no problems. Recently it just stopped working. When I press the power button the set comes on for about 2 seconds and then shuts off. After doing some research I found out how to pull up the error code which is 22. This states a "short protect circuit problem."
Any suggestions on how to start attacking the problem?
Big Fe
There is a good possibility
There is a good possibility that you have problems with the convergence IC's. Try this to find out: locate the POWER board (middle board having the big heat sinks) and test the two fuses F9A04 and F9A05 for opens. If either has failed, you need to replace both convergence IC's to repair your set.
parkie7
Thank you so much for the
Thank you so much for the suggestion, I was wondering if you or anyone knows where I can find the pictures of the DM board. I know I saw them on this site before and now I can't find them. They would be helpful if I could see them again
evil
There are some documents from
There are some documents from larry called Most Bad Caps - I think, that can be found in the technicians corner under the resources tab.
