samsung TXP2775HX/XAA no picture & no sound
4 posts / 0 new
Fr0st
Hello I have a samsung TXP2775HX/XAA with no picture and no sound I am not sure where to begin. It blinks 6 times on the power indicator.
Big Fe
These sets typically have
These sets typically have problems with the horizontal output transistor. Namely, I find that tapping the transistor will effectuate the set turning on temporarily. Use samsungparts.com to locate and order this part. Its located on the top board on a heat sink.
Fr0st
where can i find this inside
where can i find this inside the televison. I search and cannot located the part. thanks
Big Fe
If you cannot find this part,
If you cannot find this part, you probably should have a more qualified tech do this repair. It's too dangerous otherwise.
