Sony KDS-R60XBR1, no audio or color!
6 posts / 0 new
porfiry
No audio, controls don't work except on and off button. Picture is very dark and is black and white. Green light flashes for two minutes before picture comes on. I have replaced the lamp to no avail. Any idea to what be the cause?
zapdbf
Sounds like it could be the q
Sounds like it could be the q box, does the remote work ? if not and not front panel buttons, the q box has caused this kind of issue before. The picture can have various kids of issues. Some people might say it was the optical block, but this has no effect on the remote control or front panel buttons. This is the q box part number A1152712A it is quite expensive, if you do try to purchase this and replace it make sure that you check the return policy and make sure you return the core if they want it to prevent a core charge.
This part is a combination of several pc boards that work together; it contains the main micro and video processing circuits, virtually impossible to troubleshoot. Be very careful when removing there are many wires and connectors of all types. All will have some kind of clasp holding the wire in don't tug on the wires without releasing the clasps.
porfiry
The remote doesn't work,
The remote doesn't work, except the on and off button. I can also get to the self diagnostic function with the remote. The self-diagnostic screen display showed a fault: "Audio-Prot 1"
zapdbf
There is an sb about this
There is an sb about this issue, and the fix is the q box, but to be on the safe side before you buy the q box make sure that you can return it if it does not fix your problem. You don't want to get stuck. I have not seen this problem that much it is kida rare. I work for a Sony authorized service center.
porfiry
zapdbf said: There is an sb
zapdbf said: There is an sb about this issue, and the fix is the q box, but to be on the safe side before you buy the q box make sure that you can return it if it does not fix your problem. You don't want to get stuck. I have not seen this problem that much it is kida rare. I work for a Sony authorized service center.
How much is a new q box? I don't want to spend too much money on this dog.
zapdbf
expensive about 400-500 bucks
expensive about 400-500 bucks. I wish i had a better answer for you.
I am not looking at the set, it is much easier and more accurate for the tech to do the diagnostic his self, you may want to call a tech out to verify what i am saying. What you are telling me sounds like this problem but the tech may discover something else in his diagnostic. A visual inspection is usually revealing.
