Hi - I have a 62525 dlp, replaced all the known problem CAPs on the PWB, DM, FMT and some on the Signal board but I still have purple/green horizontal lines. Is the IC9A20 on the pwb the regulator causing this? Any help is appreciated!
Thanks again!
I have the same issue. Replaced power supply, format, boards. No change. I don't have a spar DM board. Lines are not on the menu and pictures from the card reader. HDMI, S video, component, composite, RF all have lines.
