Ok so I have a wd-62528 that blinks for ~70s green light, then stops, but tv does not power up. I checked the fuses F9A01 through F9E11, everything ok there. I cannot find FG901, GFF9G21, F9G41, (1) Where are these guys located??
I can sometimes get the tv to power up for about 20 seconds, but then it powers off. What else should I check?? The screen comes on, but then turns off super fast. Sounds like the fan in the DM PCB area is still on so it still has some form of power. Is there a sensor that is being triggered that is forcing the shut down?
Does this model suffer from the bad capacitor problem as other mitsi's? Should I spend time / money to replace the caps?
Please help!!! Thanks! :)
CORRECTION: I cannot find F9G01, F9G21, F9G41, (1) Where are these guys located??
also when i do device + menu to check the error code nothing is scanned out, thanks again for the ideas / help!
