I am trying to help a friend fix his Sharp Aquos LCD (52D64U) that has not turned on since being plugged in during a lightning storm. I checked the power supply board and everything is reading normal in the Primary Section. The only thing coming out of the Secondary Section is a 2.5V lead to the board for the power button.
I would really appreciate some help narrowing down the source of the problem (or if it's even repairable). Is it possible that there is a short in the line coming from the power button causing nothing to happen when button is pressed?
I can provide additional details if necessary to help a response.
