Mitsubishi WD52525 No Video - Sound OK
3 posts / 0 new
Hedhunter
Replaced the "normal" bad caps on the Power, DM and FMT board as well as 2 caps on the terminal 1 board. Hooked everything up, still had blinking light so di dthe switch mod on the FC connector. The TV now starts up, I see the menus fine, can see pictures through the card reader but have no video coming through the inputs but the sound does come through.
Do any of you Mits techs have an idea where to go to from here. I did open the chassis back up to check for a missing connection on a board but found nothing.
Thanks,
Hedhunter
entreri
Go here: http://www.techlore
Go here: http://www.techlore.com/forum/thread/30507/Mitsubishi-Service-Manuals/
Scroll to the bottom and click on "No Video Fix" see if that file helps you.
Hedhunter
YES, on screen display and
YES, on screen display and menues work so I know it is not bulb or light engine ptoblem
