Hello,
I would like to take advantage of the experts here. This is the situation. I have a Panasonic PT-53wx42f with surprise, surprise convergence issues. The TV was given to me and the previous owner put new SKT392-110 convergence chips in it. He said this helped the problem a lot but didn’t fix it. Here are some details. I did a visual inspection didn’t see any bad solder points or bad components. I’ve measured all the convergence resistors and they were all correct. The convergence voltage is -18.2 and +17.5 VDC. I am unable to move any of the beams using the basic convergence setup, but I can adjust them in the service menu. I have been able to adjust it to correct the convergence in the middle of the screen but not on the edges and the blue and red beam are wavy. Any suggestions are welcome. I've attached a link to a picture of the problem. Thanks
http://s955.photobucket.com/albums/ae37/tchinds/?action=view¤t=con...
I purchased a new set of STK392-180 convergence chips and installed them. I still have the same problem so I'm 99% sure it's not the convergence chips. Any suggestions/help?
Hi,
I looked at your image, nice.
If the customer convergence menu allows you to make a Red Horizontal adjustment (Red cross or intersection moves left and right), then all is good. You need convergence alignment. Do all the points using on-screen instruction. If not good enough, do again, starting with center adjustment and check each position (1-9) If customer controls do not align close, then you must do adjustment in service menu. Do course mode first, then touch up points with more if you have the time and patience.
If the Red Horizontal adjustment does not move the red vertical line from side to side, you still have a fault.
Faults could be:
easyab
If you are repairing a Panasonic RPTV that had STK 392-110, use 110 or 120 ICs. If you use the 180, the value of the low ohm resistors will not be correct for efficient operation. Re-design of the convergence circuit is required. 180 and 110 ICs have different charecteristics and require different value low ohm resistors when substituted. Panasonic have made many million TVs. Panasonic engineers are very clever fellows, top notch in the TV design area.
The salesman touting "Replacement/substitution" ICs is mis-informed. Also beware of poor quality and just plain "Dud" ICs, many are sold by the flashiest websites.
There is no description of what "same" problem you are having. Low ohm resistor(s) for functions that do not work are most likely open from the initial failure and have to be replaced. Resistors that are partially damaged in the initially failure sometimes open when new ICs are installed. They measure ok with an ohmmeter when checked at the time of the IC change and open when the new ICs are turned on.
easyab
I had the three blink lights problem, so I replaced both STK 392-110's with STK 392-120 and replaced all the 2.2 ohm (SKU 440-2.2 / PN 2W2D2) resistors from www.mcmelectronics.com. Because, one of the original 2.2 ohm resistors showed signs off heat, so even though it measured fine, I replaced all those resistors.
The TV works fine for a day, but today the picture now has the convergence problem.
Thoughts...
