I have a WS-65411. About two weeks ago I turned the tv off to goto bed. Came back to it the next day after work and turned it on. The green light on the front came on for 2-3 seconds and went back off. After reading alot online, I found how to check the error code. Came back with error 22. Here is what I did so far:
-Just replaced the convergence chips " stk392-110's and 2 burnt 3.9 ohm 2 watt resistors and a 5 amp pico fuse. Have fixed all the problems with error code 22 and the tv turns on now. I have a service manual and reset all values to factory settings after seeing that the green raster was bowed. Green raster bows at top and bottom which is causing colors to be off. Have used 4 sets of new sanyo ic chips to make sure that was not it. I am very good with soldering and desoldering. I also have a very good meter. I am able to adjust red and blue convergence up, down, side to side with no problem.
what could cause green raster to be off? If anyone knows, please help.
Thanks in advance.
