PT-53WX54J IC's overheat & TV turns off
5 posts / 0 new
Mr Bob
I replaced the IC's, & now I get a picture for about 5 minutes.  Just when I thought it was fixed, the darn thing turns off, & the LED blinks 3 times.  I double checked the resistors & my solder job... to no avail.
 Any thoughts?
kazkillinger
did u use hella thermal paste
did u use hella thermal paste on the ic's?
Mr Bob
I used heat compound from
I used heat compound from Radio Shack & It must be working because the heat sinks are getting very HOT!
kazkillinger
http://www.tvrepairkits.com
Mr Bob
It's FIXED! I replaced the
It's FIXED! I replaced the IC's a second time. The problem must have been either the IC's got damaged the first time, or SANYO IC's are better.
Good Luck to you other folks.
