I have a westinghouse lcd tv that went to pink screen on the component inputs(but menus are in full color). If you hook coax from cable to tv picture is ok. If you use rca inputs picture is ok. Just component cable connections are affected. Has anyone else seen this problem before.
Any help would be appreciated
I would try to narrow down the problem by attempting a couple of things:
1. Try the same video source with different component cables (to determine if your current cables are bad)
2. Try the same video source on a different TV (to determine if what you're hooking up to the TV has bad component inputs)
For example, it could just be bad cables, or something is wrong with your video source (i.e., DVD player, etc.)
If you determine that the problem lies in neither your component cables nor your video source that you are attempting to connect, it could be an issue with the component inputs on your TV (or another issue) that might require service.
Both component cables (1 from Cable box, 1 from x box) have the same problem. i took the component cable and hooked it up to rca connections and it seems to be working fine.
