I just got a Mitsubihi WD-52525 I cant hook up my laptop to it when i hook it up i can hear it but i cant see nothing theres lots of line it work on the pc hook up that ill like to use HDMI hook up can anyone help me? Thanks
Copyright © 2020
Can you give more information about the laptop and how you have it connected? Also, what settings did you use or change when trying to get it to work?
i have a dell inspirion 1525. on the tv i created a laptop connection. set it as laptop the connection to go in the hdmi? any suggestions thanks
The HDMI input on the WD-52525 is not PC capable, meaning it will not accept common PC resolutions. If you wish to use HDMI, you'll need to adjust your output settings to match a 480i, 480p, 720p, or 1080i compatible signal.
The nice part though is that you can skip all that. Your TV does have a PC capable input. It's VGA, and will accept VGA, WVGA, SVGA, WSVGA, XGA, and 720p resolutions. It's much more PC friendly. Your laptop sports a VGA output, use that and this will be much easier.
ok thank i tried the vga and it works. im going to change setting from my laptop or from the tv. thanks
thanks alot for your feedback. good info take care any problems i would e-mail you again
My pleasure. I'm glad you're up and running. :-)
