My WD-52725 has a problem that I've yet to read about. Hopefully
someone can give me some insight as to what the issue is and how to go
about troubleshooting it.
Upon plugging the set into the surge, it blinks green and goes through
the normal boot process. After booting is finished and I try to power
on the TV,
the green power LED turns on and stays solid green as it should. The
only problem is there is no picture. I do not see light coming from the
lamp, but the lamp is not even six months old. I' m not sure if there
is audio because I cannot navigate through the menu to change inputs.
There are no error codes nor any unusual LED light patterns indicating
what the failure might be. I did have the infamous B.G.L.O.D.
associated with this set in the past. I replaced all the 3300uf 10v
caps and 1000uf 16v caps and have had no issues at all for over a year.
This just happened suddenly, one day I came home and no picture. There
was no bad weather and the set is on a battery backup to protect against power outages.
Any help on this issue would be much appreciated
