I have a 42" Dell W4201C Plasma... I have no Pic on the TV... I have pulled the back cover and found that the voltages were not right on the test points in TV... Removed cable from Power Supply to XSUS board and problem persists.. Removed Power Cable to YSUS board and problem persists... Removed power from both boards and I get good voltages on the power supply... I would assume the problem is in these 2 boards... Is there something else I should look for or is there a common failure on these boards like a cap or something? The TV has samsung guts in it... Below are the model #'s... Let me know if you can help...
PDP Panel S42AX-YB01
XSUS LJ41-02758A
YSUS LJ41-02759A
Thanks for any help you can give...
It will be the LJ41-02759a board,if you have no sound,and the green led flashes 12 times on the main board.
Hi I am looking for the display panel I have a electrograph plasma that uses that panel, which I am trying to find. Your problem may be the control board it turns on the VS supply and a few others, I believe the VS voltage should be about 195vdc the control board is under two other boards mounted on a seperate piece of metal that goes across the back bottom.If you want to sell the panel let me know my e-mail is [email protected] Most common failure is the sustain and the two buffer boards mounted on the left side of the tv. Thanks hope this info helps
