Larry, or anyone
I have a Mitsubishi v21 WS-B55 with a error code 22
I have looked at all the fuses and there ok. when I plug in the tv it goes through its self check and boot up just fine. I do the menu + device hold down for 5 secs and get a error code of 12 witch its a all clear. I turn on the tv and it turns on the right back off. now I get a error code of 22. I replaced the caps in the Dm board, I also replaced the stkf2866 chip and still no worky!
can you give me a list of things that would cause a Error code 22. I am geting back to the drawing board to see if I can find any bad caps on the power side of things
I will also Update when I have its fixed. I hate people who post there problem and never say what fixed it . thank you
-Brian
**************************UPDATE********************************
Replace the Caps in the Dm board and I was having a problem with the Tv not turning on after boot up.
Tv now turns on! here is what I did....
Pluged it in, waited for the 70 Sec Boot up time after the green light stoped blinking i pusted Menu + device at the same time while it was giving me the error code 12 I pushed power and the tv tuened on!
if your trying this you may have to do this a few times for it to work. I think the tv has a error memery.
But it worked!!!
*****************************NEW PROBLEM*************************************
Got the tv to turn on, ?But now the the red and green are out of focus ANY IDEAS???
Check these two 5 amp picos F9A04 and F9A05 on the power board if they are open replace the convergence Ics.
During a bad rain storm, I abruptly lost power and the green power light began to blink continuously. After about two hours, we regained power and the power light continued to blink. I've tried to turn the TV on for the next six hours, but no change; the green light still blinks, even when I unplugged it! It has been thirty six hours now with no change. Is there anyway I can troubleshoot it? Oh, I almost forgot to mention that I've tried the system reset button countless times but to no avail. What can I do? P.S. The TV was plugged into the wall instead of a power strip prior to the blackout.
YOu have bad caps in the Digital board shout be 7 of them, REPLACE WITH 680mf 16v
