C. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Error Code Description
12 No error has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
C. Error Codes
C. Error Codes
search for error 22 or Short Protect circuit in other Mitsubishi posts and see what parts it took to fix them.
there is a Mitsubishi model to chassis cross reference in the download section to check which chassis you have, a wt-a42 is a vk20 chassis
http://www.techlore.com/download/24867/Mitsubishi-CRT-PTV-model-to-chass...
C. Error Codes
