Mitsubishi 52525
3 posts / 0 new
tmarshall
Mitsubishi 52525
Larry,
I have a Mitsubishi 52525 with the green blinking light issue. I have seen that you have sent others instructions on how to fix. Can you please also send me these instructions. I have replaced the 4 capacitors in this set before just wondering if there is a possibility I need to change other caps as well. My email address is [email protected] Thanks for any assistance you can provide!
ehofkypa
Larry,
Larry,
I also have the Mits 52525 with the BGLOD. Please send me the instructions on how to fix this. Thanks. Eric ([email protected])
Parlock
Larry,
Larry,
I own a Mitsubishi 52525 DLP with the BGLOD. :(
What I have done so far:
Replaced all of the capacitors on the Power Supply Board & DM Board that looked suspect. (4 of them were puffed) Put set back together, still BGLOD.
I took out each board and searched for ANY signs of additional capacitor issues replacing all of the capacitors that were listed as possible suspects in older posts. Put back together, still BGLOD.
After scratching my head in disbelief that the set still wouldn't work, I noticed a faint clicking noise coming from the power board. This noise has a direct impact on the fan (above the DM board) RPM's. When the power board is clicking the fan spins at a higher RPM. When the board stops clicking momentarily, the fan slows down almost to a stop.
This makes me think the problem is with the power board but I can't seem to pinpoint exactly what it is. I AM SO CLOSE..... :-)
I am new to this forum, but have been reading your extensive info about the Mits 52525 and could really use your expert advise on where you feel I need to look. Any thoughts or comments would be very helpful.
Thank you in advance.
