Hi Guys,
Anybody has a solution for a problem I am having with the repair of a Mitsubishi DLPTV?
The set came in dead with orange LED blinking. I replaced the 1000uF caps with 680uF caps in the DM and FMT boards as advised in the service info from Mitsubishi. Result is that the set is still dead but now green LED is blinking continuosly. Tried deactivating the keyboard lock feature by holding the Menu button but set still won't power up.
Checked the halogen lamp and fans in the optical engine and these tested good. Voltages to the optical engine are not being switched on. However, related parts in the power supply are good.
Thanks for your suggestions.
