Sony KP46WT500 with 8 blinks
9 posts / 0 new
Jmorozco
I have a Sony KP46WT500 with 8 blinks in the led, I change the flyback and the Q8035, Q8038 and the problem continue.
When I turn on the 3 CRT turn on but turn off 2 second and the front led flash 8 times, the service manual says if the flyback problem.
any help???
Dwray
You should have got a
You should have got a complete D Board for what you spent on Fly & transistors could have almost got the Complete board Part # A1300417A from Sony for only $177.63
Jmorozco
Complete board Part # A1300417A from Sony the corect cost is $292.63 and the only I spent on Fly & transistor is $76.00.
someone it knows that he would be able to cause this problem.
Dwray
$76 for all 3 parts cheap
$76 for all 3 parts cheap aftermarket parts Want WORK in Sony TV'S !
Original Sony Flyback Part# 145328541 is $112.01
Original Sony Q8038 Part# 872903810 is $43.03
Original sony Q8035 Part# 872905013 is $13.24
Jmorozco
Which it is your
Which it is your recommendation that buy all complete board.
Dwray
Yes if the Problem is D Board
Yes if the Problem is D Board NEW Board = Fixed Set So simple and easy remove OLD defective Board install NEW Board watch TV !
Jmorozco
I repair the board D and when
I repair the board D and when turn on the STAND BY / TIMER led blink 5 times, I check the error but say is faulty in (A Board, CR, CG, CB and G2 Board) anyone have Idea what board is the problem.
Thrasher
A-1300-417-A Sony D board
A-1300-417-A Sony D board where can I get this board for less than retail?
I need a cheap one somewhere
Thrasher
