RCA HD52W59... no pic but has sound...
spidy3
I just got a Rca hd52w59 tv from a friend who said the screen went purple one day and hasnt worked since. I just tried to hook up my Ipod to the front inputs and there is sound but no picture. when I go to the menu everything is doubled. almost like you are suppose to have 3d glasses on to view it. any info will help. looking to fix myself so if anyone had same problem and knows the part and where to get it to fix it Im confident on putting it in myself. thanks!
spidy3
i guess i can answer my own
i guess i can answer my own question. Just spend some time messing with it and Im pretty sure the adjustments that are behind speaker cover for the colors and focus.. that those knobs are loose/worn/going bad. I basically started messing with the color adjustments and a picture finally came up then I just focused in as good as I could then did the auto adjustment/alignment in the menu. now everything works. not a bad tv for free! Hope this can help someone.
