Pioneer in standby
bpetty39705
Pioneer in standby
I have a Pioneer SD P4681K that is stuck in standby mode. It happened after the power went out. Any suggestions on what the problem is???
Your problem is in the power
Your problem is in the power deflection board on this TV set. Unfortunately, the part is very expensive. You can get the board from HERE You might be able to have someone repair the board for you. It is probably a regulator Issue or something like that. If you can read a schematic and follow circuit flow, you might be able to get a manual from the place where the board is. If you do not have any solid state repair experience, play it safe and call in a pro to assist you in the repair. Good Luck with the repair.
