I need to know how to get scratches from my flat screen TV
mominttown
My 3 year old daughter thought it would be a good idea to take a pencil to our flat screen TV. It's Mitsubishi flat panel rear projection..... Please help me, my husband is very very upset with my little one at this moment. If I can fix it this, it might save my family unitLaughing
zapdbf
a flat panel is not a rear
a flat panel is not a rear projection, if it is a rear projection, it may have a piece of Plexiglas covering the screen, this usually can be replaced with a clear piece of hardware store Plexiglas cut to the same size. If it is a flat panel you may be out of luck most flat panels have the glass as the viewing surface which is not  replaceable. but i cannot be sure with your set. It may have a clear plastic covering, this could be purchased from the manufacturer. As far as rubbing it out we have tried this before but with only marginal success, we have been able to polish it out before, but it seems to leave a noticeable smear after it is done, due to the un even surface. Your best bet is to replace it if possible.
