I have a 50" Phillips Projection TV and the screen looks like it is melting.
3 posts / 0 new
TammyLW
I have a phillips 50" projection tv and the screen has a red cast to it and it almost looks like the picture is melting.  It is very blurry and has a lot of red in the color.  It just started doing this.  I am not sure if I want to put money into it or not.  It is 6 yrs old.
zapdbf
Your discription doesn't help
Your discription doesn't help me very well, can you post a picture of the problem?
TammyLW
I had it repaired this
I had it repaired this weekend.  It was the IC's   He replaced the blue and green.  He also told me later on down the road I should replace the coolant in the tubes.  He says the picture will be even crisper if I do that.  Thank you for the reply though.
