Samsun 65 making me jumpy
4 posts / 0 new
grego
I posted a question the other day, its on page 3, tv is 4 years old, projection, and the picture is erratic for lack of a better word. It seems to flicker like I had a bad video connection or some sort of static. Has anyone else ever had this bug????? I'm open to any and all ideas on this, Thanks, Grego. Color and everything else is fine.
zapdbf
I personally don't work on
I personally don't work on Samsung’s that much, seen a few across my bench. It sounds like a signal problem of some kind. Something wrong on the signal boards, is it intermittent or does it do it all the time?, is it only on the tuner or does it do in on the inputs? is it doing it on hd inputs, or the standard video inputs? Test these before you answer to make sure it can be isolated.
grego
Thanks for responding, it
Thanks for responding, it does seem like a signal issue the way it acts, I've plugged in the satellite feed at the input on the side and the ones in the back with the same what seems like a reception issue. I've jiggled the input plug to see if it might be a loose connection but as I said it does the same thing regardless of where its plugged in. I'm not sure I understand about the tuner part of your question. I really appreciate your time, Thanks, Grego.
zapdbf
Ok then you are not using the
Ok then you are not using the tunner in the television, just the video or hi-def inputs?
