I have already changed the capacitors in the DM module and it didnt solve the problem.
I feel this problem is in the protection circuit. Seems like the power supply will not stay on.
After i plug the tv in,I wait 70 sec for the timmer light to go out. There is a code 12. when I push the power button I can hear the relay K9A50 click,cycling on and off. There is voltage at the horizontal out put transister wich comes and goes with the click.
I havent checked for HV output but I can hear the whine of HV when the set clicks on, but no picture or sound.Then is clicks off.
If I unplug the yoke conector the set just clicks on then powers off and stays off.
Is there a common resistor that opens some where?I have checked Q5A51 and it tests good.
