Canon Grips
5 posts / 0 new
Tony UK
Canon Grips
Hi
I have a Canon 300D with a BG-E3 Grip/power pack.
I am looking to upgrade to a Canon 40D which uses a BG-E2 grip.
What I want to know is if the BG-E3 can be used on the 40D - I think the answer is no but wondered if anyobe knew for certain?
Chris Miller
Tony,
Tony,
You are correct.  The BG-E3 works with the Digital Rebel / 300D/350D line of Canons.  The BG-E2 works with the 20D/30D/40D line, which are different body styles.  To the best of my knowledge, there's no way to use an E3 on a 40D.
Chris
Tony UK
Thanks Chris
Thanks Chris
 Will have to start saving!
Tony UK
Also, can you tell me what
Also, can you tell me what the diiference is between the BG-E2 and the BG-E2N? The N seems to be the same just with weatherproofing but seems a lot more expensive? Is that right?
 Tony
Chris Miller
Tony,
Tony,
I don't own either grip for my 30D, but from what I've read/heard, the E2N is an upgraded version of the E2.  Primary improvements in the E2N are the weatherproofing for the battery compartment and a better textured grip.
Chris
