ws-55613 tv problem
piks
ws-55613 tv problem
had a blinking green light, replaced the four 16v 1000uf caps with 35v 1000uf caps, I think I replaced the right ones. Now no green light and no power up. I need some help please . Thanks Skip
Skip, I need a little more
Skip, I need a little more information. Where were the 4 bad capacitors located at, and you need to double check your work and make sure all of the plugs and cables are plugged into the circuit board all the way.
