Help............ 65 inch wd62825 2 yrs old.Okay I change the caps on the DM board Check the fuse which is good made sure everything was put back the way it should. Powered up the tv fan works and timer light only nothing else.
Copyright © 2020
Ladyluck,
Join the club. I have a Mits 62525 and the exact same problem. I replaced the caps and checked the fuses. I am now going to check the voltages from the power supply. I have taken the electrical chassis apart three two times now. I found a company (PTS) that will fix the DM board for $175 but I don't have a method of determining positively that the DM board is bad!?
Keep me posted.
Where is PST located? it might be worth a try.
PTS (800-844-7871) will repair your DM board for $175.00+shipping. I asked what this $175 covers and they said they will repair the board as long as it does not have damage caused by liquid or burns.
HTH
