My Mitsubishi WS-65513 Big Screen started blinking and would not stop . So I came to this website where alot of people were having the same trouble . I read where the trouble was in the (DM) Board with the 4 , 16v1000 capacitors . That was all I needed I unplug the set and open up the back . Started looking for the BM Board it was on the left side looking into the set (in a case ). I unplug two wires from the top of BM board and removed about six screws, removed it . When I removed the DM board from the case the 4 , 16v cap`s where group in one corner removed all 4 capacitors . Replaced them with new ones . I read where someone used 20v1000 or 16v hi temp cap and some boards use 7 capacitors . Put the DM Board back in the case and put back in the set . Plug the set back in, turn on TV it will blink for about 2min. , go off I turn TV set back on also put the tv cable back .The set is working great . I did not need a manual for this fix, on the DM board just look for the 16v cap`s and replace them all . After reading the forum All the time I spent was about a hour . Same day FIX . Thanks to all of you . dj229
Where did you get the caps to fix the problem
