Hey So I have a problem with a Phillips magnavox that my father currently ownes..... the problem is we have turned the brightness and contrast all the way up and it still is very dim nothing like it was when we first bought it. I was wondering does it need a new bulb or a ciruite somewhere or even if we just need to clean something.
Please HELP?!
It could need a fluid change, does it have a blue haze, with a greenish-red picture ?
Hey umm sorta.....How would i go about changing the fluid? and where would i buy this fluid?
Also when we were watching a movie on it in widescreen it was leaking color of a greenish tint into the top and bottem part of the screen that is normally all black.
That makes sense, it probibily needs a fluid change.
Here are some instructions that larry had, but most likely you don't have the white expansion chambers, you probibily have a black plug.
Moderator October 15, 2007 12:40 PM Comment updated October 15, 2007 12:49 PM
I have the directions to change the fluid, and I have done this many many times. It goes like this:
Changing Projection TV Coolant
1. Tip the TV set so the expansion chambers are pointed up. The expansion chamber is a small white/clear plastic bulb-like thing that is attached to one side of each of the CRT's up near the top lens. In some TVs, the expansion chambers are already pointed up - In this case you don't have to tip the TV
2. Cover the circuit boards below the CRT's with several paper towels to prevent accidentally spilling any coolant onto the boards.The coolant is corrosive and will destroy the circuit boards. Don't skimp on the paper towels here - they are cheap!!!
3. Remove the four screws that hold on the focusing lens assembly and remove the focusing lens assembly.
4. Note the position of the expansion chamber then remove the expansion chamber. It will need to be reinstalled in basically the same position so remember the position or take a picture if you need to. There is a small o-ring on the neck of the expansion chamber where it threads onto the CRT housing - Don't loose it!
5. Use the baster and tube to suck the fluid out from the hole where the expansion chamber was removed. This hole is fairly small...maybe 5/16" or so.
6. Once most of the fluid is out, remove the four screws that hold on the lens cover plate.
7. Remove the lens cover plate, the lens & the large o-ring. (be gentle with the o-rings!!!)
8. Clean the CRT chamber & lens with denatured alcohol. Use 100% cotton balls so you don't scratch anything.
9. Clean the CRT chamber and lens with distilled water. Again, use 100% cotton balls so you don't scratch anything. This will rinse out the alcohol residue. You need to use distilled water for this so there is no mineral residue.
10. Gently clean the large o-ring with distilled water (don't use the alcohol because it might eat the o-ring) Dry off the o-ring and lightly coat it with 100% pure silicone (not siliconized acrylic caulking or acrylic latex caulking - ONLY USE 100% SILICONE).Use your fingers to rub a thin layer of silicone all over the surface of the o-ring. Then place the o-ring in the groove in the CRThousing.
11. Place the lens in its position on the o-ring.
12. Place the lens cover plate over the lens and install the four screws.
13. Clean your baster and tubing with denatured alcohol then rinse with distilled water.
14. Use the baster and tube to suck clean fluid from the bottle and install it into the CRT through the expansion chamber hole. Goreally slow when it is almost full to minimize overflow. Wipe up any overflow immediately. There will be a small air pocket inthe CRT when you are done - you will not be able to fill the chamber 100% - This is O.K. Just be sure to fill it as far as possible so the fluid is just up to the edge of the expansion chamber hole.
15. Install the expansion chamber. Be sure to install it in the same position as it was before you removed it. Also be sure that the small o-ring is on the neck of the chamber before you thread it on. The chamber is just plastic so don't over-tighten it or you might damage it. Screw it on as tight as you can go by hand and then give it about 1/8 of a turn with pliers. (you might have to use needle-nose pliers to get a good grip on it.)
16. Place the focusing lens assembly into position and install the four screws.
17. Turn on the TV and check for leaks over the next 20 minutes. Remember, you have not yet removed all the paper towels from inside the TV. Remove these once you know there are no leaks.
Other things that should be done after replacing the fluid include...
1. Clean the mirror
2. Clean the top lenses of the focusing assemblies
3. Focus the CRT's
4. Adjust the convergence
Here is a list of things you will need:
1. Turkey baster
2. Vinyl tube
3. Cooling Fluid
4. 100% cotton balls
5. Paper towels
6. Denatured alcohol
7. Distilled water
8. Pliers
9. Screw driver
Ordering Coolant:
www.mcminone.com Part #483531067032, This is the original Philips fluid.
1. Clean the mirror
3. Focus the CRT's
1. Turkey baster
2. Vinyl tube
3. Cooling Fluid
5. Paper towels
7. Distilled water
8. Pliers
9. Screw driver
Ordering Coolant:
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
