Hi,
I got yesterday from a freind RCA TV 36 - CRT (~10 years old).
now, i have some DVDs which they are PAL (DVD is multisystem / multizone) - when i play the DVD the sound is OK but the picture is black and white.
any way to configure / setup on the TV???
thanks
Yaniv
If the TV set is a US model, then there should be an output mode on the DVD player to change from PAL to NTSC. You said the DVD player was a multisystem, so this should be the case. You should be able to go into the menu of the DVD player and find it there. Good Luck
ok
thanks a lot i will try it later today/
yaniv
