Sony ... KDF-55WF655 ... 6 Flashes
Pugsley
I Have A Sony KDF-55WF655 Thats Flashing 6 Reds ...
According To The Service Manual ... No "DD 6Volt" ... Possibly Replace G1 Board ...
G1 Is Not My Problem ... I Have No AC Going To G1 ...
The G1 "AC-Rly(-)" Logic Is Being Stopped By "TH-FUSE" Logic Coming Thru G2 ...
"TH-Fuse" Appears To Be A Temperature Fuse Link, Physically Next The Primary Lamp ...
 Anyway, I Checked Thru The Parts Section Of The Service Manual, Couldn't Find Part # ...
Part Is Approx. 10" - 2 Conductor Cable Harness With A Temp Link On The End Of It ...
Anyone Have A Part # For "TH-FUSE" Assembly???
zapdbf
i see this allot, the 6 blink
i see this allot, the 6 blink shutdown is usaly the thermal fuse under the lamp.
Part Number 1-910-023-93
the fuse you get may be totaly diffrent than the one that you take out. there are two styles one that is in a metal can under the lamp and the other one is a small black plastic one, the small black plastic one goes on the left hand side all the way to the top of the black bracket under the bulb, there is a small bracket to place the new black  fuse into.
you may already have the black fuse in the tv, or you may have the metal one with the two screws in the bottom of the bracket, it is hard to say which one you will be dealing with.
