red shadows
3 posts / 0 new
zenith
red shadows
I have a 52 big screen tv made by zenith and now i get a second red shadow an all of the objects on the screen is this somthing that can be fixed the tv is about 4 years old.
It sounds like you have the
It sounds like you have the typical convergence problem. This will involve changing the convergence IC's or changing the registration module. This is not really a hard job to do, but you will need some TV repair knowledge on this type of TV set. Also you might need to do some alignment after the board or the IC's are replaced. My best advice is, if you do not have any printed circuit board repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Did you get the Ic's for this
Did you get the Ic's for this set? what numbers did you use?
