i have a jvc projection tv av-48wp30 that wont turn on. the blue power light comes on i can hear it power up then it clicks off and the light starts flashing. the convergence ics have been replaced but it still wont turn on is there any one out there that can help me fix it.
Is this the problem you had before you replaced the convergence IC's? Was the set dead, or was there picture and sound? If not, why did you replace the IC's?
the person i bought the tv set from said the right side of the piture was blurry and could not ajust it out with the convergence on the remote. he had a technician look at it he replaced the convergense ics he said it made the picture worse.apparently he used some cheap knockoff ics or something thats why i replaced the ics with the factory originel parts .anyways thay manage to get the picture looking good some how he took it home it worked about a week then would not turn on anymore.
Disconnect the ICs and see if they are shorted. Did you use heat sink compound on the replacement IC's?
the ics are new i put them in two days ago to see if that was why the tv was not turning on
