I have an older rear projection tv that started to have picture problems. I took it apart and found the mirror cracked. The picture is bending and the color won't line up what could it be???????????
What mirror is cracked? That could be your problem. How did the mirror crack? Are you positive about the model number? Is this set in the USA? Do you know how old it is? Look at the model number again in the rear of the TV set please.
Larry Dillon said: What mirror is cracked? That could be your problem. How did the mirror crack? Are you positive about the model number? Is this set in the USA? Do you know how old it is? Look at the model number again in the rear of the TV set please.
the mirror that is on the back of the tv back It is a 1996 model The model # is correct
marcos55 said: I press on off and it clicks ,like it is on then a light click and nothing. never gets T V on but sounds like it is.It is only 2 yrs old 50+ inchs
Whats the model number and I need a little bit more in detail please. Does the front light blink or stay on? If it blinks, what is the blink code?
how do I tell whether it is or isn't? Is there a special thing I need to look for?
It is a HD1080 Mitsubishi
Any help would be great,and t y to all that r tring to help
The tv is in the USA
