I need help cleaning my 60" sony rear projection tv. I have like a plastic screen with little squares that has crayon on it. Could I use a little soft bristle brush to get this off?Thanks in advance for your help.
Copyright © 2020
No do not use a bristle brush, as there is a coating on the screen. You will take off the coating and you will see a discoloring on the screen. You can take a shammy cloth dipped in hot water and get the crayon off that way. Do not rub in a circular motion, only up and down. Continue to do this with the hot water and the shammy till all of the crayon is removed. There is a slight possiblity you will need to replace the screen if the crayon is imbedded deep into the screen, as to get it off may cause a discoloration. Good Luck, and let us know how you made out with this screen.
Thanks for the info, I will give that a try now.
