Old TV Does Not Work Right With Cable Box Remote
rdb
I have a 25 year old Hitachi Ct 1929. I have a cable box. When I program the Sientific Atlanta controller, in order to get the volume and mute to operate the tv switches from channel 3 to channel 2 or 4 after about 10 minutes on it's own. If I don"t program the volume into the controller the tv works fine , no switching by itself. Anyone have a solution to this problem? Thanks RDB
I'm afraid that with a set
I'm afraid that with a set this old, there are going to be several remote codes that will work different parts of your TV set, and this is not a fault with Hitachi or with the cable box manufacturer.  You see they, the cable manufacturer, do not include sets this old as it is really rare that a set of this age is still being used.  So to answer your question,  If the set is still operating in great condition, you will simply have to use a separate remote provided with the TV set, or get a new TV.  Good luck
