tv-vcr-dvd-connections
3 posts / 0 new
bigbaz
i have a lcd with built in freeview a dvd player and a vcr i have just found out that i cannot watch channels 1 to 4 and tape channel 5 (we do not receive 5 other than via freeview) my / is A. do i have to now buy another freeview box and B. if so how do i connect all the scart leads?
If all of this is built in,
If all of this is built in, you should be able to do what you wish to do, but you must not have something configured or set up properly.  If I were you, contact the manufacturer, as the unit may have a problem with it.  Good Luck, and let us know how you made out with this problem.
John Johnson
Larry Dillon said: If all of
Larry Dillon said: If all of this is built in, you should be able to do what you wish to do, but you must not have something configured or set up properly.  If I were you, contact the manufacturer, as the unit may have a problem with it.  Good Luck, and let us know how you made out with this problem.
Sorry but i have 3 pices of equipent !-how do i connect the scart leads?
