2 vertical lines on lcd tv
3 posts / 0 new
will_m68
I have an lcd 60 inch tv. there are 2 vertical lines that show up on the screen.  They split the screen in 3rds.  Sometimes they go away.  Any Idea on what is wrong?
Will
MOtvGuy
If these are a solid color,
If these are a solid color, are there regardless of the input, are also there if you throw the menu screen up then you've got a bad LCD panel.
MOtvGUY is correct, but if I
MOtvGUY is correct, but if I may add something. I have in the past, seen bad connection on the ribbon cables connecting the screen to the driver board, on the older models.
