Mitsubishi vs-5062 sqeezed picture
dwa961
I have this Mitsubishi rear projection tv vs-5062 that has a pic problem
It is warping the pic to the center from the sides and the top and bottom, some say this is a
pincushion effect. which this most accuratly decribes. It is not real bad yet but enough to notice.
Is there some kind off adjustment for this or is it a conponet failing or weak maybe. I dont have a service manual on this one yet. I have electronic experence, This tv is marked made in 1993.
thanks for any help
You can get a service manual
You can get a service manual downloaded from HERE  This problem you are having is most likely a capacitor or a transistor in the pincussion or the sweep power supply circuit.  you will need to measure all of the voltages in the sweep power supply and see if any of those voltages are low. if they are. check or replace the filter capacitor in that circuit, or just use an ESR capacitor meter and start checking capacitors, as this meter you can check caps in circuit. Good Luck, and let us know how this repair turns out.
