i need help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sony rear projection tv model no. rvp-6000qmb
was working fine and without warning it has stated to play up. the problem is that i get power to standby but when i try to power on the tv it tries to start then i hear a solanoid click and then it goes back to standby. don't understand why this has happened can someone tell me whether this can be fixed or how to fix it? as this would be a waste of one monster tv
That is not a good sony model number check it again. and if it is shutting down you should be getting a blink code, the led will blink for a number of times then pause then repeat the same sequence, the blink code is importat to an inital diagnostic.
